Restores all configuration parameters on the specified ports to their default values. This command does not disable gPTP on the ports.
port_list | Specifies one or more of the switch's physical ports. |
all | Specifies all of the switch's physical ports. |
N/A.
Use this command to restore all configuration parameters on the specified ports to their default values.
# unconfigure network-clock gptp ports all # unconfigure network-clock gptp ports 1,2
This command was first available in ExtremeXOS 15.3.
This command is available on platforms that support the AVB feature pack license and have it installed. For complete information about software licensing, including how to obtain and upgrade your license, and which platforms support the AVB feature, see the Switch Engine v33.1.1 Licensing Guide document.
